Cross-Country Skiing Power Data
You can use your compatible Forerunner® device paired with the HRM-Pro™ accessory to provide real-time feedback about your cross-country skiing performance.
NOTE:
The
HRM-Pro accessory must be paired to the
Forerunner device using
ANT® technology.
If your
Forerunner device was packaged with the
HRM-Pro accessory, the devices are already paired.
Power is the force you generate while skiing. The power output is measured in watts. Factors that affect power include your speed, elevation changes, wind, and snow conditions. You can use power output to measure and improve your skiing performance.
NOTE:
Skiing power values are generally lower than cycling power values. This is normal and occurs because humans are less efficient at skiing than they are at cycling. It is common for ski power values to be 30 to 40 percent lower than cycling power values at the same training intensity.
Parent Topic: Skiing and Winter Sports
