Broadcasting Heart Rate Data to Garmin Devices
You can broadcast your heart rate data from your Forerunner® device and view it on paired Garmin® devices.
NOTE: Broadcasting heart rate data decreases battery life.
  1. From the heart rate widget, hold Menu symbol.
  2. Select Heart Rate Options > Broadcast Heart Rate.
  3. Press START.
    The Forerunner device starts broadcasting your heart rate data, and Heart rate broadcast symbol appears.
  4. Pair your Forerunner device with your Garmin ANT‍+® compatible device.
    NOTE: The pairing instructions differ for each Garmin compatible device. See your owner's manual.
    TIP: To stop broadcasting your heart rate data, press STOP from the broadcast heart rate screen.
Copyright © Garmin. All rights reserved.GUID-42E081B7-11AC-4739-AA63-CA7BF685811B v10
