Playing Golf Before you play golf, you should charge the device (Charging the Device). From the watch face, select START > Golf. Go outside, and wait while the device locates satellites. Select a course from the list of available courses. If necessary, set your driver distance. Select Yes to keep score. Select UP or DOWN to scroll through the holes. The device automatically transitions when you move to the next hole. After you complete your activity, select START > End Round > Yes. Parent Topic: Golfing
Playing Golf Before you play golf, you should charge the device (Charging the Device). From the watch face, select START > Golf. Go outside, and wait while the device locates satellites. Select a course from the list of available courses. If necessary, set your driver distance. Select Yes to keep score. Select UP or DOWN to scroll through the holes. The device automatically transitions when you move to the next hole. After you complete your activity, select START > End Round > Yes. Parent Topic: GolfingHomeActivities and AppsOutdoor ActivitiesGolfingPlaying Golf
