Recording a Bouldering Activity
You can record routes during a bouldering activity. A route is a climbing path along a boulder or small rock formation.
  1. Press START.
  2. Select Bouldering.
  3. Select a grading system.
    NOTE: The next time you start a bouldering activity, the watch uses this grading system. You can hold Menu symbol, select the activity settings, and select Grading System to change the system.
  4. Select the difficulty level for the route.
  5. Press START to start the route timer.
  6. Start your first route.
  7. Press Lap symbol to finish the route.
  8. Select an option:
    • To save a successful route, select Completed.
    • To save an unsuccessful route, select Attempted.
    • To delete the route, select Discard.
  9. When you are done resting, press Lap symbol to start your next route.
  10. Repeat this process for each route until your activity is complete.
  11. After your last route, press STOP to stop the route timer.
  12. Select Save.
Copyright © Garmin. All rights reserved.GUID-42E081B7-11AC-4739-AA63-CA7BF685811B v10
