Navigating to the Starting Point of Your Last Saved Activity
You can navigate back to the starting point of your last saved activity in a straight line or along the path you traveled. This feature is available only for activities that use GPS.
  1. Select START > Navigate > Activities.
  2. Select your last saved activity.
  3. Select Back to Start.
  4. Select an option:
    • To navigate back to the starting point of your activity along the path you traveled, select TracBack.
    • To navigate back to the starting point of your activity in a straight line, select Route.
  5. Select DOWN to view the compass (optional).
    The arrow points toward your starting point.
Copyright © Garmin. All rights reserved.GUID-42E081B7-11AC-4739-AA63-CA7BF685811B v10
