Using the Weight Scale
If you have an ANT‍+® compatible weight scale, the device can read the data from the weight scale.
  1. From the home screen, select > Weight Scale.
    A message appears when the weight scale is found.
  2. Stand on the scale when indicated.
    NOTE: If using a body composition scale, remove shoes and socks to ensure that all body composition parameters are read and recorded.
  3. Step off the scale when indicated.
    TIP: If an error occurs, step off the scale. Step on when indicated.
Copyright © Garmin. All rights reserved.GUID-D543C968-08D6-4FAF-B907-D70963D29E87 v3
