Setting Your Elevation
If you have accurate elevation data for your present location, you can manually calibrate the altimeter on your device.
  1. From the home screen, select > System > GPS > Set Elevation.
  2. Enter the elevation, and select .
Copyright © Garmin. All rights reserved.GUID-D543C968-08D6-4FAF-B907-D70963D29E87 v3
