Restoring Your Personal Records You can revert a personal record back to the previous saved record. From the home screen, select > Personal Records. Select . Select a record, and select . NOTE: This does not delete any saved activities. Parent Topic: Personal Records
Restoring Your Personal Records You can revert a personal record back to the previous saved record. From the home screen, select > Personal Records. Select . Select a record, and select . NOTE: This does not delete any saved activities. Parent Topic: Personal RecordsHomeTrainingPersonal RecordsRestoring Your Personal Records
