Using Auto Pause
You can use the Auto Pause® feature to pause the timer automatically when you stop moving or when your speed drops below a specified value. This feature is helpful if your ride includes stop lights or other places where you need to slow down or stop.
NOTE: History is not recorded while the timer is stopped or paused.
  1. From the home screen, select Edge device setup symbol > Activity Profiles.
  2. Select a profile.
  3. Select Auto Pause > Auto Pause Mode.
  4. Select an option:
    • Select When Stopped to pause the timer automatically when you stop moving.
    • Select Custom Speed to pause the timer automatically when your speed drops below a specified value.
  5. If necessary, customize optional time data fields (Customizing the Data Pages).
    The Time - Elapsed data field displays the entire time including paused time.
Copyright © Garmin. All rights reserved.GUID-D543C968-08D6-4FAF-B907-D70963D29E87 v3
