Setting a Recurring Alert
A recurring alert notifies you every time the device records a specified value or interval. For example, you can set the device to alert you every 30 minutes.
  1. From the home screen, select > Activity Profiles.
  2. Select an activity profile.
  3. Select Alerts.
  4. Select Time, Distance, or Calorie.
  5. Turn on the alert.
  6. Enter a value.
  7. Select .
Each time you reach the alert value, a message appears. The device also beeps if audible tones are turned on (Setting the Device Tones).
Copyright © Garmin. All rights reserved.GUID-D543C968-08D6-4FAF-B907-D70963D29E87 v3
