Pairing a Heart Rate Monitor
Before you can pair, you must put on the heart rate monitor.
  1. Bring the device within range (3 m) of the heart rate monitor.
    NOTE: Stay 10 m away from other ANT‍+® sensors while pairing.
  2. Select > Heart Rate > Enable > Search.
    When the heart rate monitor is paired with your device, the sensor status is Connected.
Copyright © Garmin. All rights reserved.GUID-D543C968-08D6-4FAF-B907-D70963D29E87 v3
