Before you can pair, you must put on the heart rate monitor or install the sensor.
Pairing is the connecting of
ANT+® wireless sensors, for example, connecting a heart rate monitor with your
Garmin® device.
Bring the device within range (3 m) of the sensor.
NOTE:
Stay 10 m away from other
ANT+ sensors while pairing.
From the home screen, select
Select a profile.
Select a sensor.
Enable the sensor, and select
Search.
When the sensor is paired with your device, the sensor status is
Connected. You can customize a data field to display sensor data.
