Creating a Course on Your Device Before you can create a course, you must have an activity with GPS data saved to your device. Select > Courses > > Create New. Select an activity on which to base your course. Enter a name for the course, and select . The course appears in the list. Select the course, and review the course details. If necessary, select Settings to edit the course details. For example, you can change the name of the course or turn on Virtual Partner®. Select > RIDE. Parent Topic: Courses
Creating a Course on Your Device Before you can create a course, you must have an activity with GPS data saved to your device. Select > Courses > > Create New. Select an activity on which to base your course. Enter a name for the course, and select . The course appears in the list. Select the course, and review the course details. If necessary, select Settings to edit the course details. For example, you can change the name of the course or turn on Virtual Partner®. Select > RIDE. Parent Topic: CoursesHomeTrainingCoursesCreating a Course on Your Device
