Setting Range Alerts
If you have an optional heart rate monitor, cadence sensor, or power meter, you can set up range alerts. A range alert notifies you when the device measurement is above or below a specified range of values. For example, you can set the device to alert you when your cadence is below 40 RPM and over 90 RPM. You can also use a training zone (Training Zones) for the range alert.
  1. Select Edge device setup symbol > Activity Profiles.
  2. Select a profile.
  3. Select Alerts.
  4. Select Heart Rate, Cadence, or Power.
  5. If necessary, turn on the alert.
  6. Enter the minimum and maximum values, or select zones.
  7. If necessary, select Checkmark symbol.
Each time you exceed or drop below the specified range, a message appears. The device also beeps if audible tones are turned on (Setting the Device Tones).
Copyright © Garmin. All rights reserved.GUID-D543C968-08D6-4FAF-B907-D70963D29E87 v3
