Using Shimano Di2 Shifters
Before you can use Di2™ electronic shifters, you must pair them with your device (Pairing Your ANT‍+ Sensors). You can customize the optional Di2 data fields (Customizing the Data Pages). The Edge® 510 device displays current adjustment values when the sensor is in adjustment mode.
Copyright © Garmin. All rights reserved.GUID-D543C968-08D6-4FAF-B907-D70963D29E87 v3
