Data Fields
Some data fields require ANT‍+® accessories to display data.
Balance
The current left/right power balance.
Balance - 10s Avg.
The 10-second moving average of the left/right power balance.
Balance - 30s Avg.
The 30-second moving average of the left/right power balance.
Balance - 3s Avg.
The three-second moving average of the left/right power balance.
Balance - Avg.
The average left/right power balance for the current activity.
Balance - Lap
The average left/right power balance for the current lap.
Battery Level
The remaining battery power.
Battery Status
The remaining battery power of a bike light accessory.
Cadence
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
Cadence - Avg.
Cycling. The average cadence for the current activity.
Cadence - Lap
Cycling. The average cadence for the current lap.
Calories
The amount of total calories burned.
Calories - Fat
The amount of fat calories burned. Requires a New Leaf® assessment.
Calories to Go
During a workout, the remaining calories when you are using a calorie target.
Course Pt. Dist.
The remaining distance to the next point on the course.
Di2 Battery Level
The remaining battery power of a Di2 sensor.
Dist. - Lap
The distance traveled for the current lap.
Dist. - Last Lap
The distance traveled for the last completed lap.
Dist. to Dest.
The remaining distance to the final destination. You must be navigating for this data to appear.
Dist. to Go
During a workout or course, the remaining distance when you are using a distance target.
Dist. to Next
The remaining distance to the next waypoint on the route. You must be navigating for this data to appear.
Distance
The distance traveled for the current track or activity.
Distance Ahead
The distance ahead or behind the Virtual Partner®.
Elevation
The altitude of your current location above or below sea level.
ETA at Destination
The estimated time of day when you will reach the final destination (adjusted to the local time of the destination). You must be navigating for this data to appear.
ETA at Next
The estimated time of day when you will reach the next waypoint on the route (adjusted to the local time of the waypoint). You must be navigating for this data to appear.
Front Gear
The front bike gear from a gear position sensor.
Gear Ratio
The number of teeth on the front and rear bike gears, as detected by a gear position sensor.
Gears
The front and rear bike gears from a gear position sensor.
GPS Accuracy
The margin of error for your exact location. For example, your GPS location is accurate to within +/- 3.65 m (12 ft.).
GPS Signal Strength
The strength of the GPS satellite signal.
Grade
The calculation of rise (elevation) over run (distance). For example, if for every 3 m (10 ft.) you climb you travel 60 m (200 ft.), the grade is 5%.
Heading
The direction you are moving.
Heart Rate
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
HR - %HRR
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
HR - %Max.
The percentage of maximum heart rate.
HR - Avg.
The average heart rate for the current activity.
HR - Avg. %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
HR - Avg. %Max.
The average percentage of maximum heart rate for the current activity.
HR Graph
A line graph showing your current heart rate zone (1 to 5).
HR - Lap
The average heart rate for the current lap.
HR - Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
HR - Lap %Max.
The average percentage of maximum heart rate for the current lap.
HR - Last Lap
The average heart rate for the last completed lap.
HR to Go
During a workout, the amount you are above or below the heart rate target.
HR Zone
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
Laps
The number of laps completed for the current activity.
Lights Connected
The number of connected lights.
Location at Dest.
The last point on the route or course.
Location at Next
The next point on the route or course.
Odometer
A running tally of distance traveled for all trips. This total does not clear when resetting the trip data.
PCO
The platform center offset. Platform center offset is the location on the pedal platform where force is applied.
PCO - Avg.
The average platform center offset for the current activity.
PCO - Lap
The average platform center offset for the current lap.
Pedal Smoothness
The measurement of how evenly a rider is applying force to the pedals throughout each pedal stroke.
Power
The current power output in watts. Your device must be connected to a compatible power meter.
Power - %FTP
The current power output as a percentage of functional threshold power.
Power - 10s Avg.
The 10-second moving average of power output.
Power - 30s Avg.
The 30-second moving average of power output.
Power - 3s Avg.
The 3-second moving average of power output.
Power - Avg.
The average power output for the current activity.
Power - IF
The Intensity Factor™ for the current activity.
Power - kJ
The accumulated work performed (power output) in kilojoules.
Power - Lap
The average power output for the current lap.
Power - Lap Max.
The top power output for the current lap.
Power - Last Lap
The average power output for the last completed lap.
Power - Max.
The top power output for the current activity.
Power - NP
The Normalized Power™ for the current activity.
Power - NP Lap
The average Normalized Power for the current lap.
Power - NP Last Lap
The average Normalized Power for the last completed lap.
Power Phase - L.
The current power phase angle for the left leg. Power phase is the pedal stroke region where positive power is produced.
Power Phase - L. Avg.
The average power phase angle for the left leg for the current activity.
Power Phase - L. Lap
The average power phase angle for the left leg for the current lap.
Power Phase - L. Peak
The current power phase peak angle for the left leg. Power phase peak is the angle range over which the rider produces the peak portion of the driving force.
Power Phase - L Pk. Avg
The average power phase peak angle for the left leg for the current activity.
Power Phase - L Pk. Lap
The average power phase peak angle for the left leg for the current lap.
Power Phase - R.
The current power phase angle for the right leg. Power phase is the pedal stroke region where positive power is produced.
Power Phase - R. Avg.
The average power phase angle for the right leg for the current activity.
Power Phase - R. Lap
The average power phase angle for the right leg for the current lap.
Power Phase - R. Peak
The current power phase peak angle for the right leg. Power phase peak is the angle range over which the rider produces the peak portion of the driving force.
Power Phase - R Pk. Avg
The average power phase peak angle for the right leg for the current activity.
Power Phase - R Pk. Lap
The average power phase peak angle for the right leg for the current lap.
Power - TSS
The Training Stress Score™ for the current activity.
Power - watts/kg
The amount of power output in watts per kilogram.
Power Zone
The current range of power output (1 to 7) based on your FTP or custom settings.
Rear Gear
The rear bike gear from a gear position sensor.
Reps to Go
During a workout, the remaining repetitions.
Speed
The current rate of travel.
Speed - Avg.
The average speed for the current activity.
Speed - Lap
The average speed for the current lap.
Speed - Last Lap
The average speed for the last completed lap.
Speed - Max.
The top speed for the current activity.
Speed Zone
The current range of your speed (1 to 10). Zones can be set in Garmin Connect™.
Sunrise
The time of sunrise based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Temperature
The temperature of the air. Your body temperature affects the temperature sensor.
Time
The stopwatch time for the current activity.
Time Ahead
The time ahead or behind the Virtual Partner.
Time - Avg. Lap
The average lap time for the current activity.
Time - Elapsed
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
Time - Lap
The stopwatch time for the current lap.
Time - Last Lap
The stopwatch time for the last completed lap.
Time of Day
The time of day based on your current location and time settings (format, time zone, daylight saving time).
Time Seated
The time spent seated while pedaling for the current activity.
Time Seated Lap
The time spent seated while pedaling for the current lap.
Time Standing
The time spent standing while pedaling for the current activity.
Time Standing Lap
The time spent standing while pedaling for the current lap.
Time to Dest.
The estimated time remaining before you reach the destination. You must be navigating for this data to appear.
Time to Go
During a workout, the remaining time when you are using a time target.
Time to Next
The estimated time remaining before you reach the next waypoint in the route. You must be navigating for this data to appear.
Torque Effectiveness
The measurement of how efficiently a rider is pedaling.
Total Ascent
The total elevation distance ascended since the last reset.
Total Descent
The total elevation distance descended since the last reset.
Vertical Speed
The rate of ascent or descent over time.
VS - 30s Avg.
The 30-second moving average of vertical speed.
Copyright © Garmin. All rights reserved.GUID-D543C968-08D6-4FAF-B907-D70963D29E87 v3
