Following a Segment From the Web
Before you can download and follow a segment from Garmin Connect™, you must have a Garmin Connect account (Garmin Connect).
  1. Connect the device to your computer using the USB cable.
    NOTE: If you are using Strava™ segments, your favorite segments are transferred automatically to your device when it is connected to Garmin Connect Mobile or your computer.
  2. Go to www.garminconnect.com.
  3. Create a new segment, or select an existing segment.
  4. Select Send to Device.
  5. Disconnect the device, and turn it on.
  6. Select Segments.
  7. Select the segment.
  8. Select Map > RIDE.
Copyright © Garmin. All rights reserved.GUID-27471316-3AC6-405B-9AF1-096A08B50787 v4
