Enabling Segments You can enable Virtual Partner® racing and prompts that alert you to approaching segments. Select Segments. Select a segment. Select Enable. NOTE: Prompts alerting you to approaching segments appear only for enabled segments. Parent Topic: Segments
Enabling Segments You can enable Virtual Partner® racing and prompts that alert you to approaching segments. Select Segments. Select a segment. Select Enable. NOTE: Prompts alerting you to approaching segments appear only for enabled segments. Parent Topic: SegmentsHomeTrainingSegmentsEnabling Segments
