Setting Target Power Select > Indoor Trainer > Set Target Power. Set the target power value. Select an activity profile. Start pedaling. The resistance force applied by the trainer is adjusted to maintain a constant power output based on your speed. If necessary, you can adjust the target power output during your activity. Parent Topic: Using an ANT+ Indoor Trainer
Setting Target Power Select > Indoor Trainer > Set Target Power. Set the target power value. Select an activity profile. Start pedaling. The resistance force applied by the trainer is adjusted to maintain a constant power output based on your speed. If necessary, you can adjust the target power output during your activity. Parent Topic: Using an ANT+ Indoor TrainerHomeTrainingUsing an ANT+ Indoor TrainerSetting Target Power
