Before you can use a compatible
ANT+® indoor trainer, you must mount your bike on the trainer and pair it with your device (Pairing Your
ANT+ Sensors).
You can use your device with an indoor trainer to simulate resistance while following a course, activity, or workout. While using an indoor trainer, GPS is turned off automatically.
Select
Select an option:
Select
Follow a Course to follow a saved course (Courses).
Select
Follow an Activity to follow a saved ride (Going for a Ride).
Select
Follow a Workout to follow a power-based workout downloaded from your
Garmin Connect™ account (Workouts).
Select a course, activity, or workout.
Select
RIDE.
Select an activity profile.
Select
to start the timer.
The trainer increases or decreases resistance based on the elevation information in the course or ride.
