Replacing the Speed Sensor or Cadence Sensor Battery
The LED flashes red to indicate a low battery level after two revolutions.
  1. Locate the circular battery cover Callout number one on the back of the sensor.
    Battery replacement with callouts
  2. Twist the cover counter-clockwise until the marker points to unlocked and the cover is loose enough to remove.
  3. Remove the cover and the battery Callout number two.
    TIP: You can use a piece of tape Callout number three or a magnet to remove the battery from the cover.
    Battery with a callout
  4. Wait 30 seconds.
  5. Insert the new battery into the cover, observing polarity.
    NOTE: Do not damage or lose the O-ring gasket.
  6. Twist the cover clockwise until the marker points to locked.
    NOTE: The LED flashes red and green for a few seconds after battery replacement. When the LED flashes green and then stops flashing, the device is active and ready to send data.
Copyright © Garmin. All rights reserved.GUID-27471316-3AC6-405B-9AF1-096A08B50787 v4
