Setting Range Alerts
If you have an optional heart rate monitor, cadence sensor, or power meter, you can set up range alerts. A range alert notifies you when the device measurement is above or below a specified range of values. For example, you can set the device to alert you when your cadence is below 40 RPM and over 90 RPM. You can also use a training zone (Training Zones) for the range alert.
- Select .
- Select a profile.
- Select Alerts.
- Select Heart Rate Alert, Cadence Alert, or Power Alert.
- If necessary, turn on the alert.
- Enter the minimum and maximum values, or select zones.
If necessary, select
Each time you exceed or drop below the specified range, a message appears. The device also beeps if audible tones are turned on (Setting the Device Tones).
Parent Topic: Alerts
