Route Settings
Select , select a profile, and select .
- Routing Mode
Allows you to select an activity for the device to calculate your route (Selecting an Activity for Route Calculation).
- Calculation Method
Allows you to select the calculation method to optimize your route.
- Lock on Road (requires routable maps)
Locks the position icon, which represents your position on the map, onto the nearest road.
- Avoidance Setup (requires routable maps)
Allows you to select the road type you want to avoid.
- Recalculation (requires routable maps)
Allows you to select the recalculation method when you deviate from the route.
Parent Topic: Navigation
