Conducting an FTP Test
Before you can conduct a test to determine your functional threshold power (FTP), you must have a paired power meter and heart rate monitor (Pairing Your ANT‍+ Sensors).
  1. Select Menu symbol > My Stats > FTP > FTP Test > RIDE.
  2. Select Pause and play symbol to start the timer.
    After you begin your ride, the device displays each step of the test, the target, and current power data. A message appears when the test is complete.
  3. Select Pause and play symbol to stop the timer.
  4. Select Save Ride.
    Your FTP appears as a value measured in watts per kilogram, your power output in watts, and a position on the color gauge.
Copyright © Garmin. All rights reserved.GUID-27471316-3AC6-405B-9AF1-096A08B50787 v4
