Calibrating Your Power Meter
Before you can calibrate your power meter, it must be properly installed, paired with your device, and actively recording data.
For calibration instructions specific to your power meter, refer to the manufacturer's instructions.
  1. Select Edge device setup symbol > Sensors.
  2. Select your power meter.
  3. Select Calibrate.
  4. Keep your power meter active by pedaling until the message appears.
  5. Follow the on-screen instructions.
Copyright © Garmin. All rights reserved.GUID-27471316-3AC6-405B-9AF1-096A08B50787 v4
