Replacing the Heart Rate Monitor Battery
  1. Use a small Phillips screwdriver to remove the four screws on the back of the module.
  2. Remove the cover and battery.
    Close-up view of the heart rate monitor battery being replaced
  3. Wait 30 seconds.
  4. Insert the new battery with the positive side facing up.
    NOTE: Do not damage or lose the O-ring gasket.
  5. Replace the back cover and the four screws.
    NOTE: Do not overtighten.
After you replace the heart rate monitor battery, you may need to pair it with the device again.
Copyright © Garmin. All rights reserved.GUID-27471316-3AC6-405B-9AF1-096A08B50787 v4
