Broadcasting Heart Rate Data
You can broadcast your heart rate data from your watch and view it on paired devices. Broadcasting heart rate data decreases battery life.
TIP: You can customize the activity settings to broadcast your heart rate data automatically when you begin an activity (Activities and App Settings). For example, you can broadcast your heart rate data to an Edge® device while cycling.
  1. Select an option:
    • Hold MENU, and select Sensors & Accessories > Wrist Heart Rate > Broadcast Heart Rate.
    • Hold CTRL to open the controls menu, and select Broadcast heart rate data.
      NOTE: You can add options to the controls menu (Customizing the Controls Menu).
  2. Press START.
    The watch starts broadcasting your heart rate data.
  3. Pair your watch with your compatible device.
    NOTE: The pairing instructions differ for each Garmin® compatible device. See your owner's manual.
  4. Press START to stop broadcasting your heart rate data.
September 2025
