Pairing Your Wireless Sensors
Before you can pair, you must put on the heart rate monitor or install the sensor.
The first time you connect a wireless sensor to your watch using ANT‍+® or Bluetooth® technology, you must pair the watch and sensor. If the sensor has both ANT‍+ and Bluetooth technology, Garmin® recommends that you pair using ANT‍+ technology. After they are paired, the watch connects to the sensor automatically when you start an activity and the sensor is active and within range.
  1. Bring the watch within 3 m (10 ft.) of the sensor.
    NOTE: Stay 10 m (33 ft.) away from other wireless sensors while pairing.
  2. Hold MENU.
  3. Select Sensors & Accessories > Add New.
    TIP: When you start an activity with the Auto Discover option enabled, the watch automatically searches for nearby sensors and asks if you want to pair them.
  4. Select an option:
    • Select Search All.
    • Select your sensor type.
    After the sensor is paired with your watch, the sensor status changes from Searching to Connected. Sensor data appears in the data screen loop or a custom data field. You can customize the optional data fields (Customizing the Data Screens).
September 2025
