Stopping an Activity
  1. Press START.
  2. Select an option:
    • To resume your activity, select Resume.
    • To save the activity and view the details, select Save, press START, and select an option.
      NOTE: After you save the activity, you can enter self-evaluation data.
    • To suspend your activity and resume it at a later time, select Resume Later.
    • To mark a lap, select Lap.
    • To navigate back to the starting point of your activity along the path you traveled, select Back to Start > TracBack.
      NOTE: This feature is available only for activities that use GPS.
    • To navigate back to the starting point of your activity by the most direct path, select Back to Start > Straight Line.
    • To measure the difference between your heart rate at the end of the activity and your heart rate two minutes later, select Recovery HR, and wait while the timer counts down.
    • To discard the activity, select Discard.
    NOTE: After stopping the activity, the watch saves it automatically after 30 minutes.
September 2025
