Using the inReach Remote
Before you can use the inReach® remote function, you must add the inReach glance to the glance loop (Customizing the Glance Loop).
- Turn on the inReach satellite communicator.
- On your Instinct® watch, press UP or DOWN from the watch face to view the inReach glance.
- Press START to search for your inReach satellite communicator.
- Press START to pair your inReach satellite communicator.
Press
START, and select an option:
To send an SOS message, select Initiate SOS.
NOTE: You should only use the SOS function in a real emergency situation. -
To send a text message, select , select the message contacts, and enter the message text or select a quick text option.
To send a preset message, select Send Preset, and select a message from the list.
To view the timer and distance traveled during an activity, select Tracking.
Parent Topic: inReach Remote
