Recording a Bouldering Activity
You can record routes during a bouldering activity. A route is a climbing path along a boulder or small rock formation.
  1. From the watch face, press START.
  2. Select Bouldering.
  3. Select a grading system.
    NOTE: The next time you start a bouldering activity, the watch uses this grading system. You can hold MENU, select the activity settings, and select Grading System to change the system.
  4. Select the difficulty level for the route.
  5. Press START to start the route timer.
  6. Start your first route.
  7. Press SET to finish the route.
  8. Select an option:
    • To save a successful route, select Completed.
    • To save an unsuccessful route, select Attempted.
    • To delete the route, select Discard.
  9. When you are done resting, press SET to start your next route.
  10. Repeat this process for each route until your activity is complete.
  11. After your last route, press START to stop the route timer.
  12. Select Save.
September 2025
