Barometer Settings
Hold MENU, and select Sensors & Accessories > Barometer.
Calibrate
Allows you to manually calibrate the barometer sensor.
Plot
Sets the time scale for the chart in the barometer glance.
Storm Alert
Sets the rate of barometric pressure change that triggers a storm alert.
Sensor Mode
Sets the mode for the sensor. The Auto option uses both the altimeter and barometer according to your movement. You can use the Altimeter Only option when your activity involves changes in altitude, or the Barometer Only option when your activity does not involve changes in altitude.
Pressure
Sets how the watch displays pressure data.
September 2025
