Calibrating the Treadmill Distance
To record more accurate distances for your treadmill runs, you can calibrate the treadmill distance after you run at least 1.5 km (1 mi.) on a treadmill. If you use different treadmills, you can manually calibrate the treadmill distance on each treadmill or after each run.
- Start a treadmill activity (Starting an Activity).
- Run on the treadmill until your watch records at least 1.5 km (1 mi.).
- After you finish the activity, press START to stop the activity timer.
Select an option:
To calibrate the treadmill distance the first time, select Save.
The device prompts you to complete the treadmill calibration.
To manually calibrate the treadmill distance after the first-time calibration, select .
- Check the treadmill display for the distance traveled, and enter the distance on your watch.
Parent Topic: Running
