Adjusting the Watch Hands
The watch hands sync with the digital time and calibrate automatically. Occasionally, extreme shock, temperature changes, or magnetic fields can cause the watch hands to fall out of sync, or misstep, with the digital time. If the watch hands do not match the digital time, you can calibrate them or align them manually.
- From the watch face, hold MENU.
- Select .
Select an option:
Select to calibrate the watch hands.TIP: You can hold GPS and ABC to calibrate the watch hands at any time.
Select to enable or disable automatic calibration during general use.
Select to enable or disable automatic calibration during activities.
Select Set Alignment, and follow the on-screen instructions to manually align the watch hands and reset the basis for calibration.
Parent Topic: System Settings
