Calibrating the Bow Sight
The first time you turn on the Xero™ bow sight, you are prompted to go through initial setup steps. You can view tutorial videos at www.garmin.com/xerotutorials.
  1. Select a language.
  2. Select a unit of measure.
  3. Select Yes to start the pin calibration procedure.
  4. Select a ranged pin color (A1i model only).
  5. If necessary, select Yes to adjust the pin and rangefinder reticle brightness and follow the on-screen instructions.
  6. Set the primary pin (Setting the Primary Pin).
  7. Select Done.
  8. Align the rangefinder with the primary pin (Aligning the Rangefinder with the Primary Pin).
  9. Select Done.
  10. Follow the on-screen instructions to complete the pin calibration procedure and set pins for additional distances.
Copyright © Garmin. All rights reserved.GUID-F012B45E-6BEB-4C6C-A7F3-68A710C14C56 v6
