Setting Fixed Pins
Before you can set fixed pins, you must calibrate the bow sight for your current bow and arrow combination (Calibrating the Bow Sight).
From the main menu, select
- Select .
- Select a range.
- If necessary, repeat steps 2 and 3 to add additional fixed pins.
Parent Topic: Fixed Pins
