Changing the Fixed Pin Color
NOTE:
Pin color options are available only on A1i models.
There is a small offset between red and green pins. Most archers will not see changes in accuracy for shots within 45 m (50 yd.). Garmin® recommends choosing only one color of pin when setting fixed pins for distances longer than 45 m (50 yd.).
- From the main menu, select .
- Select a pin.
- Select Color.
- Select a color.
Parent Topic: Fixed Pins
