Sending Locations to a Device You can manually send ranged locations to a compatible Garmin® watch or handheld device. From the main menu, select . Select a ranged location. Select Yes. The bow sight sends the selected location to your compatible Garmin device. Parent Topic: Laser Locations
Sending Locations to a Device You can manually send ranged locations to a compatible Garmin® watch or handheld device. From the main menu, select . Select a ranged location. Select Yes. The bow sight sends the selected location to your compatible Garmin device. Parent Topic: Laser LocationsHomeUsing the Bow SightLaser LocationsSending Locations to a Device
