Customizing the Position of the Top Pin
For bow configurations that require additional vertical adjustment, you can customize the position of the top pin. This can also be useful for people who prefer the short range pins to be more centered within the device optic.
NOTE:
Changing the position of the top pin clears all arrow profile settings.
- From the main menu, select .
- Select Yes.
Press
or
to adjust the position of the top pin.
- Press OK.
- Follow the on-screen instructions to calibrate the device for the new top pin position (Setting the Primary Pin).
Parent Topic: Device Settings
