Rangefinder Measurements
When you activate the laser rangefinder, the device displays three numbers on the LCD display. The device uses these measurements to adjust the position of the pin.
The measured distance between the laser rangefinder and the target. |
The horizontal distance to the target, which is calculated using the angle of measurement. |
The upward or downward angle from the rangefinder to the target. |
Parent Topic: Using the Bow Sight
