Adjusting the Bubble Level
The bow sight contains a built-in digital level and a clearly visible bubble level. If the digital level and the bubble level do not match, you can adjust the position of the bubble level.
- Select .
- Hold the bow sight level so the display shows 0.
- Loosen the two screws located on each side of the bubble level by one quarter turn.
- Adjust the bubble level until the bubble is centered and the digital display also reads 0.
- Tighten the two screws.
Parent Topic: Calibrating the Bow Sight
