Device Settings
The device settings allow you to customize the device for your needs.
From the main menu, select
- Pins
Sets the appearance and timeout of the pins on your bow sight (Pin Settings).
- Align Reticle
Turns on the rangefinder reticle and primary pin. You can use this option to align the rangefinder reticle and primary pin, as needed.
- Laser Locations
Sets the broadcast mode for laser locations (Laser Location Settings).
NOTE: This setting is available only on A1i models. - Shot Dynamics
Enables or disables shot notifications and clears shot history (Shot Dynamics Settings).
NOTE: Some shot measurements are available only on A1i models. - Units
Sets the units of measurement used by the device (Units Settings).
- Language
Sets the device language.
- Level
Displays the angle of the bow and allows you to display a level indicator when shooting (Level Settings).
- Calibrate Compass
Allows you to calibrate the compass if you experience irregular compass behavior, for example, after moving long distances or after extreme temperature changes (Calibrating the Compass).
NOTE: This setting is available only on A1i models. - Manual Adjustment
Sets the position of pins within the device optic. You can move the position of the calibrated range stack (Moving the Calibrated Range Stack) or customize the position of the top pin (Customizing the Position of the Top Pin).
- Reset All Settings
Resets all settings to factory default values.
- About
Displays regulatory and compliance information.
