Level Indicator
When enabled, the level indicator shows when you are holding the bow level. Level indicators appear as three dots above or below your aiming pin. The top indicator flashes when the bow is canted to the right. The bottom indicator flashes when the bow is canted to the left. The bow is level when no indicators flash. You can adjust the threshold for the level indicator to allow more or less cant (Level Settings).
NOTE:
The level indicator does not appear when using fixed pins.
Parent Topic: Using the Bow Sight
