Calibrating Additional Ranges
You can add ranged pins to extend the range of your shots. Garmin® recommends calibrating a range for every 10 meters or yards. Calibrated ranges apply only to the active arrow profile. The bow sight will not provide pins beyond the farthest calibrated range.
From the main menu, select
- Select .
- Follow the on-screen instructions on your bow sight to calibrate the device for the new distance.
Parent Topic: Pin Calibration
