Setting a Training Target
The training target feature works with the Virtual Partner® feature so you can train toward a set distance, distance and time, or distance and speed goal. During your training activity, the device gives you real-time feedback about how close you are to achieving your training target.
  1. Select Menu > Training > Set a Target.
  2. Select an option:
    • Select Distance Only to select a preset distance or enter a custom distance.
    • Select Distance and Time to select a distance and time target.
    • Select Distance and Speed to select a distance and speed target.
    The training target screen appears, indicating your estimated finish time. The estimated finish time is based on your current performance and the time remaining.
  3. Select Checkmark symbol.
  4. Select Start stop symbol to start the activity timer.
  5. If necessary, scroll to view the Virtual Partner screen.
  6. After you complete your activity, select Start stop symbol > Save Ride.
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
