Installing the Mountain Bike Mount
NOTE: If you do not have this mount, you can skip this task.
  1. Select a secure location to mount the Edge® device where it does not interfere with the safe operation of your bike.
  2. Use the 3 mm hex key to remove the screw Callout number 1 from the handlebar connector Callout number 2.
    Mountain bike mount with callouts
  3. Select an option:
    • If the handlebar diameter is 25.4 mm or 26 mm, place the thicker pad around the handlebar.
    • If the handlebar diameter is 31.8 mm, place the thinner pad around the handlebar.
    • If the handlebar diameter is 35 mm, do not use a rubber pad.
  4. Place the handlebar connector around the handlebar, so that the mount arm is above the bike stem.
  5. Use the 3 mm hex key to loosen the screw Callout number 3 on the mount arm, position the mount arm, and tighten the screw.
    NOTE: Garmin® recommends tightening the screw so the mount arm is secure, with a maximum torque specification of 20 lbf-in. (2.26 N-m). You should check the tightness of the screw periodically.
  6. If necessary, use the 2 mm hex key to remove the two screws on the back side of the mount Callout number 4, remove and rotate the connector, and replace the screws to change the orientation of the mount.
  7. Replace and tighten the screw on the handlebar connector.
    NOTE: Garmin recommends tightening the screw so the mount is secure, with a maximum torque specification of 7 lbf-in. (0.8 N-m). You should check the tightness of the screw periodically.
  8. Align the tabs on the back of the Edge device with the bike mount notches Callout number 5.
    Mountain bike mount with a callout
  9. Press down slightly and turn the Edge device clockwise until it locks into place.
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
