Using an ANT‍+ Indoor Trainer
Before you can use a compatible ANT‍+® indoor trainer, you must mount your bike on the trainer and pair it with your device (Pairing Your ANT‍+ Indoor Trainer).
You can use your device with an indoor trainer to simulate resistance while following a course, activity, or workout. While using an indoor trainer, GPS is turned off automatically.
  1. Select Menu > Training > Indoor Trainer.
  2. Select an option:
    • Select Free Ride to manually adjust the resistance level.
    • Select Follow a Course to follow a saved course (Courses).
    • Select Follow an Activity to follow a saved ride (Going for a Ride).
    • Select Follow a Workout to follow a saved workout (Workouts).
  3. Select a course, activity, or workout.
  4. Select Ride.
  5. Select Start stop symbol to start the activity timer.
    The trainer increases or decreases resistance based on the elevation information in the course or ride.
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
