Exiting Extended Display Mode While the device is in Extended Display mode, select > Exit Extended Display Mode > OK. Parent Topic: Setting Up Extended Display Mode
Exiting Extended Display Mode While the device is in Extended Display mode, select > Exit Extended Display Mode > OK. Parent Topic: Setting Up Extended Display ModeHomeCustomizing Your DeviceSetting Up Extended Display ModeExiting Extended Display Mode
