Setting Range Alerts
If you have an optional heart rate monitor, cadence sensor, or power meter, you can set up range alerts. A range alert notifies you when the device measurement is above or below a specified range of values. For example, you can set the device to alert you when your cadence is below 40 RPM and over 90 RPM. You can also use a training zone for the range alert (Training Zones).
  1. Select Menu > Settings > Activity Profiles.
  2. Select a profile.
  3. Select Alerts.
  4. Select Heart Rate Alert, Cadence Alert, or Power Alert.
  5. Select the minimum and maximum values, or select zones.
Each time you exceed or drop below the specified range, a message appears. The device also beeps if audible tones are turned on (Turning the Device Tones On and Off).
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
