Pairing Your Phone
To use the connected features of the Edge® device, it must be paired directly through the Garmin Connect™ app, instead of from the Bluetooth® settings on your phone.
  1. From the app store on your phone, install and open the Garmin Connect app.
  2. Hold Power on off symbol to turn on the device.
    The first time you turn on the device, you will select the device language. The next screen prompts you to pair with your phone.
    TIP: You can select Menu > Settings > Connected Features > Phone > Pair Smartphone to manually enter pairing mode.
  3. Select an option to add your device to your Garmin Connect account:
    • If this is the first device you have paired with the Garmin Connect app, follow the on-screen instructions.
    • If you have already paired another device with the Garmin Connect app, from the Menu symbol or Menu symbol menu, select Garmin Devices > Add Device, and follow the on-screen instructions.
    NOTE: Based on your Garmin Connect account and accessories, your device suggests activity profiles and data fields during setup. If you have sensors paired with your previous device, you can transfer them during setup.
    NOTE: Setting up Wi‑Fi® and sleep mode usage on your device enables the device to sync with all your data such as training stats, course downloads, and software updates (Using Auto Sleep).
After you pair successfully, a message appears, and your device syncs automatically with your phone.
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
